Hi
I’m rebuilding my kitchen and have to insulate the outer brick walls so I’ve put up stud walls with celotex between the stud timberwork. But I’m undecided what to put over the studwork on the inside face. OK so it doesn’t need to look pretty beneath the kitchen base units, but I’d rather not leave the insulation exposed so I’m thinking of cladding the studwork from floor to ceiling with 9mm OSB. Then hardibacker board (or similar) above the worktops for tiling, and plasterboard above that - both sitting on the OSB. Additional advantage would be if the OSB is well fixed then I don't need to worry too much about noggin positions as I could use umbrella type fixings for the cabinets.
Building control need to do a 1st fix inspection, so I’m wanting to get things right. Does what I plan seem alright and normal, or any other suggestions please? I appreciate I could just OSB the lower section but I’d rather spend a few ££ more and bulk up the walls to make them less flexi. Should I consider ply instead? Any help or advice is welcomed
