I drained my CH system at the weekend and refilled with Sentinel X400 as this process was recommended by the engineer who carried out the last service (sludge build up has partially blocked a rad).
At the same time, I removed the affected rad and flushed using the garden hose. This rad now seems to be operating fine. I also cleaned the header tank (full of brown gunge).
A few questions as I am a novice at this.
(1) Do I leave X400 in for four weeks or six weeks? There seems to be conflicting advice.
(2) Additionally, do I need to vibrate or whack each radiator with rubber mallet to dislodge any sludge or will the solution do this own its own?
(3) Finally, when I drain down to refill with X100. Do I just drain down or do I need to run the head tank for a while with hose connected to a radiator? I need to drain all downstairs radiators individually as they are all on same level. There is no drain below boiler and all downstairs radiators have a drain valve.
Thanks in advance,
Drewb
Thanks in advance,
Drewb
