hi, I'm planning outdoor lighting scheme using Swa cable to suitable junction box, then I was considering using nyy-j cable to the light units - 1 about 1/2 metre away thru brickwork and another about 4 metres away with the cable under soil.
Any advice if this is ok? Nyy-j cable is perfectly suitable for outdoor use but I believe if buried it needs to be in conduit / protected?
I could just use swa to each light fitting but there would need to be a jb at each point as the fittings do not have a 20mm entry point for a gland fitting and it's easier to wire anyway with the more flexible nyy-j cable.
I'm happy to fix a jb at each point, using nyy-j cable and appropriate glands.
Many thanks for any help
