- Joined
- 7 Jan 2019
- Messages
- 6
- Reaction score
- 0
- Country
Is there any way to use two 2-channel Hive receivers in the same system using the Hot Water circuit on the second receiver to control an immersion heater via a 40A relay?
You do realise the question is about an immersion heater?A motorised valve is a relay, so yes, the relay replaced the motorised valve, but why?
This is why I said "but why" I think it is far easier to fit a timer direct to the immersion heater. Water takes time to heat and cool, so there is no need for internet control, the timed control is just to line up with off-peak supply, there is a method using two elements often a switch on the immersion bath/sink and the external immersion Willis system so we can heat varying amounts of hot water, but can't see how this could be used with Hive?You do realise the question is about an immersion heater?
He wants to use the Hive as the timer, which seems to be possible.I think it is far easier to fit a timer direct to the immersion heater.
Yes, that is what I said, but price of single channel Wiser v double channel Wiser, was more than a timer would cost, not sure with Hive, I made a mistake, it sounded good when I got it, I go iboost+ so I can use spare solar, but solar paid at 12p/kWh and off-peak is 6.5p/kWh, so a simple timer would have saved me more money. So it only paid back for 20 months while getting the MPAN number sorted out.He wants to use the Hive as the timer, which seems to be possible.
You are the biggest proponent of smart homes and odd set ups yet when someone asks a relatively innocent question you ask why? Just a bit odd...But it would work, but I repeat why would you want to?
