Hi people, i have a Vaillant 242h and it has stopped working and i haven't used it for over 8-9months. I had someone come to check it out and i was told it was the fan as the guy sprayed it with wd40 and gave it a spin and and eventually it started working.
I have been quoted it will cost £160 for part and labour and it will take near 2 hours. Now i am pretty handy and have found the manual and it says for fan replacement:
Replacement of fan (fig. 55)
• Isolate the boiler from the electrical
supply.
• Remove front casing as in section
7.1.3, and remove combustion
chamber cover as in section 7.1.5.
(ABOVE DONE)
• Disconnect the electrical connections
from the fan.
• Remove the 2 fan securing screws
(4) and remove fan.
• Reassemble in reverse order.
Now im sure to pull off 2 electrical connections and 2 screws cant be that bad...seems like im getting conned. Is it worth me doing or am i missing something else?
Any help would be much appreciated as im moving in very soon.
MANUAL: http://www.acwilgar.co.uk/Boiler-Manual-PDF/Vaillant/Turbomax VUW 242E 282E.pdf
PART: http://www.ebay.co.uk/itm/VAILLANT-...Cooling_Air&hash=item415ee57cf7#ht_500wt_1156
supply.
(ABOVE DONE)
from the fan.
(4) and remove fan.
