Hi, a question for the RGI's. There are some corrosion issues with my Vaillant 418 which are safe for now, but will kill the boiler case eventually. This is caused by the boiler being fitted to a single skin exterior wall. Condensation is building up at the top rear case causing corrosion.
I plan to get a new Vaillant 418 fitted, and keep my existing one as a source of spares. I will not be fitting it myself.
The manual makes no reference to it, So I will ask, is it permitted for a Vaillant 418 to be fitted on a combustible wall? (Ie, a sheet of 18mm ply with Celotex / Kingspan insulation behind)? Just planning what the job might be next summer.
Thanks.
Thanks.
