vaillant 837 pump on when cold tap runs?
18 Nov 2008
London
Am i right in thinking this is just air in the system or something more conspicuous?
Also the pumpwa s very noisy to start leading me to believe it could be the above?
Any help would be great
thanks,
I should call back the original installer :roll:
Or give Vaillant a service call, it'll still be under warranty, won't it?
if you get nuisance startup after cold tap is run then you have a dead leg of pipework which is an installation fault. A non return valve on the dhw outlet of boiler should cure this but won't be done under warranty. Call the installer back.
