Hi, I have a Vaillant Thermocompact VC GB 242 EH which is not giving me heating. It must be at least 18 years old but has been in generally good working order.
The symptoms started as the pump going on and off. The boiler would start fine but then I noticed the pump cutting out and coming back on. This was accompanied by a microswitch type clicking which I think was coming from the main control unit. Now the CH doesn't start at all. By this I mean the programmer is on, the room stat is turned up but the pump and fan do not start. There is plenty of water in the system.
If there was a lack of water of air pressure etc I would still expect to get some action out of the boiler just not ignition. I am getting nothing. I know the pump an fan are fine as the DHW works fine.
I have checked the feed from the room stat and there is a signal getting to the boiler fine. I have also 'fooled' the system by depressing the microswitch on the diverter servo and the boiler fires up fine and starts to heat the rads.
The diverter valve, servo and the micro switches on the diverter are all relatively new. The diverter is moving ok when the DHW is sensed and returns ok when the tap is switched off.
Due to the initial symptoms and the fact I am now getting no ignition sequence at all I am starting to think it may be pcb related (or one of the switches on a pcb). Trouble is there are 4 boards - the main one with the on/off switch and 3 smaller ones connected to it. It is not possible to see anything obviously wrong with pcbs and they are not particularly cheap so don't what to play guess the pcb to replace.
Any ideas on other causes or feeds that may be preventing the ignition sequence, or any idea which pcb may be at fault (if at all).
many thanks
Lance
many thanks
Lance
