    Dismiss Notice
Vaillant Combi Boiler help please
Discussion in 'Plumbing and Central Heating' started by Dougie212, 27 Aug 2016.
  1. Dougie212
    Dougie212
    30 Mar 2007
    390
    Thanks Received:
    4
    Staffordshire
    Country:
    Thank you for all your advise everyone!! I do have it serviced and to be honest it is due one.. typically at its last service the problem was intermittent and if Im honest, i forgot to mention it. I won't be trying this as a DIY fix, boilers un-nerve me and anything involving gas is well left to the experts in my opinion. Thanks again everyone
    • Like Like x 2
  2. Sponsored Links
  3. The831Bunny
    The831Bunny
    18 Mar 2008
    1,457
    Thanks Received:
    959
    Country:
    Now, if we're being anal about this, the safety recall was only issued concerning the open flued versions of this range. The OP's pic is of a VCW242/282.
    Having said that it appears the lead seal and wire is still intact, so in the GS engineer we trust.
    She looks a good old girl as @ianmcd says. Around 1988, original pump, no bad leaks, Domestic replaced with plate kit (thats a given), Diverter looks a bit too shiny for 28YO.
    I must stop this lol!...
    • Thanks Thanks x 1
    • Like Like x 1
  4. ianmcd
    ianmcd
    15 Aug 2010
    21,498
    Thanks Received:
    8,376
    Lanarkshire
    Country:
    Great Boilers have yet to see a modern boiler that will give the service that these ladies have, OP find yourself someone who knows this boiler and it will be sorted no problem
    • Like Like x 1
  5. Dougie212
    Dougie212
    30 Mar 2007
    390
    Thanks Received:
    4
    Staffordshire
    Country:
    Thanks Ian... I have just dropped someone who is advertised as a former Valiant Glow Worm Technician in my area so hopefully they will get back to me soon. Could I also just ask, when my boiler has sat for sometime over the summer I go round and just check the bleed vales on the radiators and release a tiny bit of air, if any... Is there something on the boiler the I should bleed air from? and.... the hot water sometimes comes through cloudy, especially when the boiler has ran after the hot tap has previously ran.... (due to the original posted problem)... Is the cloudiness because the water is too hot and will therefore rectify when the original issue is solved
  6. AGAS
    AGAS
    21 Feb 2014
    9,691
    Thanks Received:
    1,710
    down south
    Country:
    na edit that
    been a while ,someone remind me what notice I'm a bit confused:D
  7. Sponsored Links
  8. ianmcd
    ianmcd
    15 Aug 2010
    21,498
    Thanks Received:
    8,376
    Lanarkshire
    Country:
    The milky water is just air bubbles in the water as it passes through the heat exchanger it gets boiled and if you leave it a few minutes it will soon clear, this happens with all combi boilers and is more common when you run the hot tap slowly, absolutely natural and nothing to worry about
  9. Dougie212
    Dougie212
    30 Mar 2007
    390
    Thanks Received:
    4
    Staffordshire
    Country:
    fantastic.. thank you!!!!! your all...(most of you..) awesome..!!
    • Like Like x 3
  10. Phill Peck
    Phill Peck
    17 Aug 2011
    17,012
    Thanks Received:
    4,187
    Cambridgeshire
    Country:
    Piston, spindle
    Potato, potAto
    OP hopefully the guy you've contacted is as good as @The831Bunny and @Bunnyman and will have it fixed in no time.
    As said there is a risk it's badly corroded but hopefully not.
  11. Bunnyman
    Bunnyman
    22 Mar 2010
    5,496
    Thanks Received:
    1,841
    Northamptonshire
    Country:
    Tony retire ffs
    • Like Like x 1
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
