Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Also when the put the water back on D NOT RUN HOT TAP run the cold for 10 mins to get rid of any debris as if u run the hot there's a good possibility you will block the plate exchanger
