Hi ,i have a eco tec plus system boiler, a 637 i think , it is 12 yo ,still going strong. As fuel prices have gone up i want to try and use the boiler more efficiently . It has always been set to run hot water and the heating at 65degrees . I set the hot water to 65 using the dials under the front cover and the heating to 45 . Heating is off at the moment, but the boiler defaults to the heating temperature and sends 45degree water to the coil in the hot water cylinder. No fault symbols displayed . I suspect the installer set it up this way . but i want to be greener . what is the solution thanks
