Vaillant EcoTEC 924 and Honeywell CM921 Thermostat
28 Dec 2009
Bedfordshire
Hi All...
I currently have a Vaillant EcoTEC 824 combi boiler fitted wit TRV's installed on all the rads. I've noticed lately that the boiler seems to be running continuously, even though the TRV's are set a desired level. I've also just had my latest gas bill and for the last two months I've used almost £400 worth of gas!!!
Therefore, I've come to the conclusion that I need to install a room thermostat so that when the ACTUAL room temperature I want is reached the boiler shuts down for a period of time rather than keep on running.
I've been recommended to get the Honeywell CM921 wireless thermostat but would like the following clarification:
1. I know the thermostat wireless reciever needs to be hard-wired to the boiler using boiler terminal 3, 4 and 5, but which teminals on the thermostat do these correspond too?
2. Many websites advise not to have a TRV's fitted on rads in the same room as the thermostat? Is this true as surely if the TRV's are set to the highest setting the thermostat will switch off the system before the TRV has chance to conflict with it???
3. Is there an easy way to remove or better still disable a TRV?
Many thanks for any advise!
