Hello Fellas, Hope some one can help me just a tad. I know I am so close but some time I cant see the wood for the trees.
links for diagrams
stat
http://content.honeywell.com/uk/homes/Catalogue/Heating Controls/2.17 T6360.pdf
boiler (go to page 27)
http://www.tradeplumbing.co.uk/asse...eco-tec/ecoTEC-installation-and-servicing.pdf
I have a Honeywell T6360B and a Vaillant ecoTEC combi Boiler.
I have successfully connected the boiler to the mains supply and also fitted the vaillant plug and play timer. Now i am trying to install the external Honeywell T6360B thermostat.
The thermostat has 4 terminals plus an additional terminal marked earth
The boiler has a set of terminals number 3, 4 and 5 for connecting external controls such as a time switch and room stat. Terminals 3 and 4 are linked when the boiler is supplied (purchased). The instructions state that if external controls are used this link must be removed and the controls connected across terminal 3 & 4. Terminal 5 is an additional neutral connection for external neutrals such as from the anticipator of a room stat.
The stat diagram shows
L connected to Stat terminal 1
N connected to stat terminal 2 (anticipator)
N connected to stat terminal 3 (through the heating load i.e BOILER)
QUESTION
1- Has Vaillant kindly provided the BOILER terminals 3, 4 and 5 to allow connect direct to the stat?
2- If YES is this the correct wiring sequence
Boiler Terminal 3 acting as a LIVE going to stat terminal 1
Boiler Terminal 4 acting as Neutral going to stat term 3
Boiler Terminal 5 acting as Neutral going to stat term 2
If these boiler terminals are a convenience could I wire up directly from the switched double pole isolator? I only ask as to better my understanding of the circuits.
Thanks kindly for all your help
DirtyDog368
links for diagrams
stat
QUESTION
DirtyDog368
