I have recently had a Vaillant ecoTEC Plus 48 boiler fitted on the recommendations of the installer and unfortunately have problems with the boiler reaching target temperature for the central heating.
It is set up with 22 radiators and an unvented cylinder in a S plan with a hive thermostat controlling on/off.
Target temperature has been set at 75c and for heating the unvented cylinder this is reached quickly and seems to work well. However when calling on the central heating the boiler struggles to go above 50 - 55c.
I have noticed that in the diagnostics D.005 changes from 75c to 60c when the central heating is called on but it stays at 75c when the unvented cylinder is being heated. Not sure why this would happen they are both being controlled by the same hive input.
Any help would be greatly appreciated.
