- Joined
- 27 Jan 2008
- Messages
- 28,905
- Reaction score
- 3,537
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My question is why would you want it that hot? The whole idea is the cooler the return water is, the more latent heat is extracted, so most boilers turn down the output if the return is too hot.
What can mess up the system is if the radiators have not been balanced correctly, one radiator with the lock shield valves wide open, can result in the boiler reducing output.
Not tried Hive, I use Wiser, but the whole idea is if any room is under temperature, it can fire the boiler, since I use oil, this is a bit different, gas users often have OpenTherm which allows the boiler to run more efficiently. What we aim for is a smooth temperature
not a sine wave
and that smooth temperature is done by not over heating and radiator or room.
not a sine wave
