Hello everyone,
It seems my heating doesn't work fine anymore
When I try to use the taps, the boiler burner starts and the water flow hot as requested
When I try to use the heating, the boiler burner starts but it stops itself after few seconds
I had a look using the button "-" on the panel and I noticed that the temperature raise over the value I set then it stops the burner.It seems a "safety control" to avoid an overheating??
Is the issue due the faulty NTC sensors?
I saw the diverter valve pushing the piston in
Any clue?
Thanks.
Any clue?
Thanks.
