Hi Folks,
Wondered if you could give me list of possible causes before I pay for a call-out? Is this anything obvious/daft? Is there anything I could check (obviously non gas related!) from a DIY perspective?
System is open vented, with a hot water tank upstairs of unknown age. The boiler is around 4 years old. What is odd is that I get hot water when the heating is on but nothing on 'hw' only. The boiler fires up momentarily, gets to about 40 degrees and goes off. I've changed the tank stat just in case as it was a 5 min job but no change. Moving the boiler HW temp knob up to max does not do anything. Moving the CH knob up to max means the boiler comes on and off all the time at weird times(ie. no demand from controller as CH off) but I get hot water.
Very strange. Any thoughts?
Cheers
Cheers
