Guys I am not touching anything inside, I am purely going on by the fault code and hoping this is just a setting issue as I believe they were changed.
F.90 – Communication with Shift Load Storage Tank Module Interrupted
This is what I found, seems to me that a shift load storage is some kind of other vaillant boiler, ie 937 with storage tank behind, or at least thats what I can find the manuals referring to.
My guess is that the DSN is changed from the access panel, I try to select d as 0 as to what it should be for this boiler (again according to manual) but f90 remains.
I press + and i together and get d. 0, press i again to confirm, then next screeen I get 2 parallel lines, what should this value be?
