Vaillant EcoTec Pro 824 Modulate Heating temperatures?
When it fires on HW , it runs at full rate so the noise you hear is the fan, thats all, if you look in the installation manual you will see that the maximum rate achievable however the boiler is set when on heating is way below this so a 24kw boiler will only give say 18kw on heating.So its the software that controls the heat output.Balancing your system is the best way to get the rads hotter quicker and by range rating the boiler as discussed but an engineer should do this. Hope this helps.
As you are not using the advanced features of the stat that can be ruled out. However I would watch the stat to ensure that it is not trying to do anything clever. It should just simply call for heat and stay calling until satisified.
The new ecotec have some very smart software on them that looks at many parameters and adjusts d0 accordingly. Pre 2012 models worked differently.
"Software"......My last boiler had a thermostat and a gas valve.
Oh......and a transformer!
