Vaillant ecotec pro ebus temperature too high
29 Jan 2025
Hello,
I have a vaillant ecotec pro boiler wired with a vaillant vrt350 thermostat (modulation enabled).
When I check the ebus target temperature it is way too high, always stuck at 90 degrees.
(I check using the diagnostic code D.009)
I reduce the circuit temperature to 50 degrees, but nothing changes regarding the ebus target temperature, always stuck at 90 degrees.
Any insight on this issue ?
Also another worrying thing is that the input and output flow temperature difference is rather low below 5 degrees, which make things that it does not condense well…
Indeed, d.009 is not adjustable, by default D.071 was at 75 degrees, I reduced it to 60 degrees, unfortunately still not change to D.009, it still stick to 90 degrees
