    Dismiss Notice
Vaillant Ecotech Plus 24 kw
Discussion in 'Plumbing and Central Heating' started by bob1956, 11 Sep 2021.
  1. bob1956
    bob1956
    15 Aug 2018
    15
    Thanks Received:
    Country:
    The hot water on the above boiler is running cold showing S53,only one fault code showing F22,I suspect that's historic.
    I have just changed the programmer because the original fault was no heating,which fixed that problem.
    However the customer asked me to check the HW supply it was then I uncounted the F53 ,the hot water initially gets hot then runs cold.
    I checked the Diagnostics D40 63 deg; D41 49 deg; although I would expect the differential to be 20 deg;
    I have no history on this boiler except I installed it 12 years ago,the owner has just moved in 2 days ago.
    Any vaillant guys out there that can throw some light on this problem
  2. Sponsored Links
  3. CBW
    CBW
    26 Sep 2019
    8,470
    Thanks Received:
    2,222
    North
    Country:
    S53 is a status code, which is generally poor circulation, so circulation pump or a blockage somewhere. There are some Vaillant guys on here @ScottishGasMan for one who can possibly shed a little more light on it than I can.
    • Thanks Thanks x 1
  4. lightning
    lightning
    14 Jul 2007
    2,117
    Thanks Received:
    458
    Cambridgeshire
    Country:
    Rubber hoses blocked or full of carp
    • Like Like x 1
Loading...
Share This Page
