I’m trying to alter the hot water temp and the flow temp on said boiler. I’ve followed the manual, thought I’d set the HW to 55 degrees but when I run the HW it goes to 65 degrees on the display. Obviously rads aren’t on so can’t check on that side. Both temperatures that I’ve ‘set’ are flashing on the display when I go into it and don’t stop flashing when I press the RH ‘tick’ button, as if it’s not confirming the setting? I’ve tried a long press, short press etc. Comfort setting can be changed on and off as per the manual by the way.
Obviously it’s not a massive issue but I’d like to not have to add cold water to the hot for showers etc.
When it’s been serviced, the engineer has never commented on the flow temperature being too high or anything but they generally only put the rads for a bit on to see if they are getting warm.
