A
ALEC1
i think compensated boilers are designed with a different understanding....and I dont think that understanding is readily available in the UK..
and on the point of system design.. I do have a house with weather comp and some micro bore and it works fine, surprisingly...
and the house doesn't even have to be particularly well insulated!
One work around if the pipe work is too small is to install a manual bypass between the flow and return cracked open very slightly to allow some flow to trickle through and raise the return temperature a bit. I'll get shouted at for saying that because it's a bit of a bodge, but there you go.
Interested in your pump in series much cheaper than a 25/80 have you literally put them one after the other without cavitation?
Any comments more than welcome
lso remember that they have released a revised board (believe only 2 people in the country have it)
