Vaillant TurboMax 824 - adjusting time between cycles
16 Dec 2013
Hampshire
Hi all,
I do have my underfloor heating system running out of my combi boiler. This needs quite low but ideally constant hot water supply in order to work efficiently. Ideally I would like to maintain the water supply within the 45-55 C deg range.
At the moment the boiler is heating water to 68 C deg and then goes into anti cycle mode for 4 minutes. At that point the water has around 30 C deg (300 m of pipes hence there is a bit to heat).
I have pump overrun for 2 minutes enabled. Then there is 2 minutes of silence and low temp.
I've looked at the manual and tried quite a few settings but I can't see how I can force the boiler into "more often but less extreme" operation.
Any suggestions how to reduce the time between the cycles (as I can control the temperature by knob)?
is your heating a mix of rads and underfloor or only underfloor ?
