Hi
I have the above boler installed which has the following fault
It has developed a fault whereby everytime you turn off the cold water tap it sounds like a click and a relay closing and LED 3 on the front panel (warm start) comes on and the fan runs for a few seconds, the boiler does not ignite and then the system returns back to normal operation. The boiler pressure is about 1.5 bar
Can anyone shed any light on the reason for this. I assume that when you turn a cold tap on the cold water inlet pressure to the boiler will drop and the only item I can see in line to this flow is the aqua sensor
Regards
Terry
Regards
Terry
