Hi. We have the Vaillant Turbomax 828 combi boilder, been here since we moved in 6 years ago. (edit: 2001 install!
Randomly, maybe once or twice a year it locks out and turning it off and on again fixes it. Usually when its *very* cold outside and the incoming water is cold.
Anyway, over last week days we've had 3+ F.24 lockouts which is more than normal. The heating was on 5-6pm then I got in the bath at 7pm and boiler was locked out. Resetting again and fine, but the hot water was very variable in temperature which I've never noticed before. (Flow was good and normal, and its a simple direct tap). After bath, wife ran more hot water, and she said the temperature varied - but I was watching the LCD and the temperature didn't fluctuate much. (edit: LCD was 65-70' - whereas HW temp is set at 42' - so that's quite a difference.... If boiler was keeping water at 65-70 and actual water was fluctuating between (guess) 20-40 - suggests Water-to-water HE blocked?)
Pressure is 1bar - and that's what it was on when we moved in so we've kept it at that.
The original pump failed a year or so ago and we replaced that, and I think pump is fine as heating works well. We have combi-mate and a magnetic trap which we clean out.
I have searched, and suggestions seem to be air-pressure switch or heat exchanger. (Is the heat exchanger the water-to-water sardine can one? Or the flame-to-water? Assume its water-to-water).
Other suggestions I've ruled out seem to be the diverter valve, but the CH pipes do not get warm unless heating is on. Pump (heating is fine when its on) Also no water in boiler, though there is. Or NTC sensors but I'm sure if that was the case the issue would be more constant.
I hear pressure should be 1.5bar when cold - is that correct? Not going to find any weak heating plumbing if I put it up am I
I've not checked the pressure-vessel but water pressure doesn't rapidly rise when hot, so assume that's OK. (What should it be? I'll check next time I drain the boiler)
From my symptoms above, which seem slightly different to other posts, any other suggestions?
(Thinking of replacing DHW HE first; failing that air pressure switch (though no idea what that does!); failing that Primary HE)
Edit: I'm sure its an 828 as that is said on the installation paperwork. Manual says the DHW HE is PN 065088 - but elsewhere PN 065153 is mentioned? (different number of plates? ) Assume the manual is the PN to use?
