My Vaillant Turbomax 828E will give me DHW without a problem but no CH. I have no fault codes stored. I have eliminated any external controls by looping connections 3 + 4 but still nothing. I have also tried removing the timeswitch. The status of the CH demand (i+-) (d08) is always zero and if i push 'i' i get 's30' code that means no ch demand from external controls.
However, I can get the CH to work by pushing both the + and - buttons together which I'm told puts it in some chimney sweep mode, although I have only let it run in this mode for a few minutes the radiators start to get hot so the pump must be working. This is the only time I can get the CH demand (d08) code to change.
I have also checked connections 3, 4 + 5 with a meter and I get 240v on connection 5 (meant to be neutral) and nothing on the rest.
Does this sound like main board failure?
If so whats the cost of a main board?
Cheers
Martyn
Cheers
Martyn
