vaillant turbowmax 242e heating problem
19 Mar 2006
Wolverhampton
hello there i have a problem with the above boiler i was removed from a property which was having an upgrade and was working perfectly before removal ,after plumbing it in up my loft to a single rad and a tap to check before fully conecting in to my system it seems that once i switch it to heating it fires and ignites burns for about 30 seconds and the the burner cuts out still leaving the pump running the temp rises to about 30 degrees has any one else had this problem p.s if i call for water that operation is fine
Sounds like the CH circuit is blocked. Have you opened the isolation valves and rad valves?
The boiler should really be properly commissioned as if it were a new installation. You may want to engage a Corgi heating engineer to do this.
tryed all it is on max at to moment i have to switch boiler off and on before it will relight some times it stays on longer than other ,max temp it reached was 60 and the heating was turned up to max
there is a little blue limet switch towards the bact of the boiler if i please it the boiler fires but when i release it shuts off where is the ntc thing
