Over the last couple of weeks have noticed the hot water sometimes not working. Recently hot water has stopped completely. A couple of days ago i decided to try switching the heating to constant and then opened hot water tap and the hot water started to work.
I tried to have a look after speaking to a few people and trying the internet to understand more. I was told to check the microswitch which might need replacing.
I have checked the microswitch by manually pressing and this time round not even the heating is working.
When i opened the hot water tap the switch was being made as the piston/arm from the servo was pressing against the micsroswitch.
I have noticed there to be a slight leak as looking underneath past the microswitch, could these be seals that would need replacing.
Here are a few more things that might help;
Pressure is fine and sometimes needs topping up to just over the 1 bar, say we top up about 3-4 times a year.
Pilot light is always on.
Initially jets were firing up when heating was switched on, but not anymore. The hot water only operated if heating was on, but doesn't happen anymore as the heating is no longer working.
I have read quite a lot into this and have been told as the boiler is 13 years old the engineers i have spoke to are advising on changing the boiler, but are reluctant to come out to do repair job as they feel this can lead to many other jobs, but they do not mind advising. They will gladly come out to change the boiler.
Please can someone help on this. Much appreciated. [/quote]
