Hi folks,
I have joined the forum after a google search showed there to be some knowledgeable folks here regarding these old Vaillant boilers!
I have had the boiler for over 20 years now and it has been a model of reliability really. The only things I have had to do to it are replace the DHW heat exchanger, the auto vent valve and the fan (twice!)
Anyway, my current problem revolves around the diverter valve. The DHW had been a bit temperamental over the past week or so resulting in it failing altogether tonight.....so I came home from work at 1o'clock in the morning with my wife begging me to sort it out so she could have a shower!
On checking the diverter valve I could see that the arm wasn't coming out far enough to release the lower micro switch. I adjusted the rod a little (2 full turns) so it now operates and still opens well after the top one and closes well before the top one does so there is still a good overlap in the operation of the two switches.
My question relates to how quickly should the diverter valve operate? With the heating on, opening a hot tap sees the valve taking about 10 seconds or so to open enough to clear the bottom switch. Shutting off the tap it then takes a good 3 1/2 minutes or so for the arm to move back enough to close the top switch and turn the heating back on. Does that sound about right or am I looking at springing for a new diverter valve.....or could the problem be elsewhere?
Many thanks for your time.
Lacy
Lacy
