I've been trying to replace the diaphragm in the water section of my VCW242E boiler.
I've got the instructions from Vaillant, and followed the steps to turn off the boiler; gas service cock, CH service cocks (x2) and the DHW cold water service cock.
The next stage was to undo the unions on the water sections. As soon as I did this water came pouring out, and not just from the tank in the boiler.
I re-tightened the unions.
Then ran the hot tap, and even in this state with the boiler supposedly isolated, water still flowed and continued to flow.
The obvious thing was to turn off the water at the stop cock (in the house) and it hadn't been used in so long that the tap snapped off.
Next problem, can't find the stop tap in the road. I'm in a terrace of 4 houses, the outer two have stop taps (which work) of their own, and the middle 2 of which mine is one has a cover under which is full of mud!
I tried digging it out as best I could but had no luck, and even if I managed to un cover the tap, I doubt I'd be able to turn it off. I've called the water board and they are going to come in up to 5 days!!
Can anyone suggest anything else I could do (or haven't done regarding the boiler??
What really stumps me is the water still flowing out of the hot tap even when the tap on the boiler is off!
