    Dismiss Notice
Vaillant VRC 470F how difficult to install?
Discussion in 'Plumbing and Central Heating' started by waveuk, 22 Jun 2014.
  1. waveuk
    waveuk
    28 Sep 2012
    20
    Thanks Received:
    London
    Country:
    I am replacing my boiler and I want also to update the controller to the VRC 470F. Would this require more work for the engenier than installing any other controller?
    The engineer is telling me they need to run some wires but what I understand from the manual is that is quite straight forward and it does not required any wire at all. Receiver is just plugged into the boiler.
    Tx
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    11,490
    Thanks Received:
    2,358
    Daventry
    Country:
    Should be just plug and play
  4. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    709
    Country:
    When the new ecotecs came out some of the controls were not compatible with the plug and play so they did need to be wired in using ebus and the back box supplied. Old boilers are 4 pin female whereas the new boilers are 3 pin male as far as i recollect! (I remember there was a big fuss about this when the new ecotecs were released. Shame on vaillant to release a boiler without updating the controls)! So your installer is half right! However they soon changed the recievers so that they now have removeable pins on the back so that they now fit both new and old. No wireing should be needed with the new stock.
    Ps. Your installer may be thinking that the outdoor sensor needs to be wired in, but it doesn't. It is wireless and has a built in solar panel so no batteries or cables are needed for it either
  5. waveuk
    waveuk
    28 Sep 2012
    20
    Thanks Received:
    London
    Country:
    Thanks!
  6. Sponsored Links
  7. waveuk
    waveuk
    28 Sep 2012
    20
    Thanks Received:
    London
    Country:
    I talked with the engineer again and he says that what needs to be wire is not the weather compensator but the eBus to HW. I have a quite old vented system and boiler is replaced by a system boiler + unvented.
    Any thoughts?
  8. gazdaz36
    gazdaz36
    28 May 2009
    548
    Thanks Received:
    169
    Kent
    Country:
    You would need a vaillant wiring centre as well
  9. ALEC1
    ALEC1
    21 Nov 2009
    9,496
    Thanks Received:
    717
    London
    Country:
    yes the wiring centre needs a cable between the boiler and the valves...usually there is one...
    the power for the wiring centre then comes from another socket
    There may even be a 5 wire connection between the boiler and valves...it all depends...
  10. GuessMan
    GuessMan
    21 Feb 2012
    1,792
    Thanks Received:
    840
    By the seaside
    Country:
    :oops: missed the system boiler bit!
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
