Vallaint Combi Turbo Max Plus loop valve pressure adjustment
28 Sep 2015
Hi,I have a Vallaint combia turbomax plus 824e boiler. The water pressure keeps drooping to 0.2. I have had a plumber in before to look at it and he increased the pressure of the loop valve with a key because the screwdriver head directly on the valve is very worn out making it impossible to adjust with a screwdriver. I am trying to find this key with recesses into the valve and allows me to adjust the pressure but I can't find one online anywhere. Would you be able to help me with this in any way ? Many thanks
Possibly an allen key. Can you post a photo?
Unfortunately for you, your boiler has probably the worst filling link design ever!
But don't worry the key is available here:
http://ebay.co.uk/itm/VAILLANT-TURB...VE-HANDLE-KEY-125151-/360491203015?nav=SEARCH
And if the valve is too damaged for the key to work, you can get the whole valve here:
http://ebay.co.uk/itm/VAILLANT-TURB...UT-NON-RETURN-014675-/361105574932?nav=SEARCH
However. If you are having to top up regularly. You need to get an engineer to diagnose why. It could either be a leak somewhere on the system or a problem with the expansion vessel or prv inside the boiler.
Regular topping up is not good for the boiler and system.
You could have an external one fitted, it would be much easier to operate, but you would need a plumber to install it so best just to get a new key for the one you have now.
That's what I was thinking Bunnyman, but knowing how there are several different systems sometimes its easier to just keep quiet in case I am wrong in this particular case!
I must be thinking of an earlier filling link. I'm sure there was a vaillant one around that was just 2 big round slotted screws, rather than the smaller square version? It came with a slotted key that was useless. i'm sure bunny will correct me if i'm wrong
