Hi there,
I've a valour adorn LFE gas fire, which when you close the slide at the end of the evening, stays on. It will eventually turn off after several minutes.
The slide linkages are apparently correct. If you disconnect the linkage and close the 'valve?' under the fire it still stays on.
Have thoroughly cleaned the fire and chimney.
I can find many articles about fires not staying on or not lighting, but nothing about them not going off..
Any ideas?
Many thanks
Any ideas?
Many thanks
