Am having cavity wall insulation done and firm will not install it without knowing the kwh rating of the fire, cannot find rating plate on fire. I am hoping to find manual to give fire rating.What's the problem?
Thanks Kev but firm want to see written proof in from of manual etc.6.85 kw input (gross)
Thanks, but unfortunately the link has not come through or I am missing it. I have emailed Valor but they have not come back to me.This is the link that SHOULD take you to manual for that fire. However, when I tried it, it wouldn't work. If you can't get it to work, a call to Valor should see them email you.
Hi Kevplumb, my email address is; [email protected]
Your right on the con part, I managed to find the sight you gave me the link for thanks, but the fires there are not the same model the model I have has 4 radiants I have not been able to find anything on this model except for the model number on a parts sight I came across selling the radiants.Have a look at www.partsarena.com/baxi
It will come up and you might be able to print the screen.
This is a bit of a con with cavity wall people so they can get 50 quid+ for fitting a vent from the un informed.
