Valves for gravity feed shower
3 Jul 2004
Hi All,
I'm intending to fit a gravity feed shower - there's about 7/8m head and it's a mira unit designed for gravity - my dad has it and it gives a decent shower with only about 2m head.
I would like to have a pull switch outside the shower cubicle that turns on the lights, the fan and the shower (to allow it to warm up before we step in). I was wondering if I could use zone valves for this purpose or if there are valves designed specifically for controlling water outlets.
Does anyone think this is a good/bad idea - I've not come across it before. I guess it will be a bit like those (expensive) digital showers that can be turned on from outside the cubicle without a temperature indicator (and the associated cost).
Thoughts?
Just turn the shower head towards the side of the cubicle, lean in and turn it on. If you want a shower you can control remotely buy one, don't waste your time bodging something together.
There's an overhead 'rain' unit that can't be turned away.
I've looked for anything that's compatible with a gravity system and the only units sold are more advanced, expensive and have a built in pump. Our shower upstairs has a pump and frankly it wakes the whole house up and probably next door.
I was hoping to simply use valves to turn the water on and off, I don't need digital temperature control or a pump. All I need is a couple of full-bore valves, but I was looking to see if anyone else has used such valves on a fresh water circuit (such as to a shower) rather than on central heating. Also, are 22mm zone valves generally full-bore?
Seriously - I don't want to botch anything, but it would be nice to have a reasonable cost solution that means I don't have to freeze my b*lls off every morning starting the shower!
Thanks,
Matt
