Hello all.
I am hopefully going to be doing a job in the local scout and guide hut shortly.
It involves the complete refurbishment of the toilets area in the building.
Two of the walls are external walls, and are constructed of 4" x 2" timber.
It is clad on the outside with what appears to be creosoted hardwood tounged and grooved boards.
The inside will be 12.5mm plasterboard with skimmed finish, and the bottom half of the wall will be tiled onto this.
I will be removing all the internal wall covering, which presently is a combination of plasterboard and hardboard.
In the wall there is about 1" of fibreglass, and what I would describe as tar paper between the external cladding, and the external face of the wall framework.
I'm going to be filling the wall with 100mm of rockwool as part of the project.
Now the question (finally
Once the wall is bare and insulated, should I cover it with a vapour barrier before I plasterboard?
I have seen some information on here about it, and seen it used in some properties, but I'm not sure.
Sorry for rattling on
