I fixed my problem with the leaking filling loop, so we're making progress!
With the initial system pressure set to 1.5 bar, I turned the heating on. The system pressure rose to approaching 3.0 bar after half an hour or so, so I turned it off and let the pressure drop again.
What I've read on this forum would suggest that the expansion vessel may be either shot, or in need of repressurising. Before I go down this route, is there any other possible reason for the pressure to rise in this way (I now know that the filling loop problem has been fixed)?
A couple of follow up questions...
I read a post which suggested that letting air INTO the system would help provide room for expansion as the system heats up? Can anyone expand (no pun intended!) on this? I've been bleeding enthusiastically since the system was drained, and I'm now thinking I've made the problem worse by doing so...
Finally (and I'm sorry to go on). I've been redecorating and I'm still one radiator short at the moment. I would have thought that if I still need to set the system pressure to 1.5 bar (regardless of how many radiators) there are in the system. Is that correct?
I've got a Sime 90 combi boiler by the way. If anyone knows how to find a valve to pressurise the expansion vessel I might consider doing it, but I'm inclined to get someone in at the moment!
Thanks very much!
Alan.
Thanks very much!
Alan.
