Varnishing internal doors - knotting?
28 May 2008
Essex
I want to varnish my internal doors, so that the wood shows through. Do I still need to apply knotting first? If so, the knotting solution I've used in the past leaves an orange stain around the knots which will look awful showing through varnish - is there such a thing as clear knotting solution?
Any advice appreciated"
The reason for using knotting solution is to prevent resin bleeding through and discolouring, especially, light coloured paint.
If you varnish wood with knots in with clear varnish they will still show, of course, but you don't need to bother about sealing them.
Great, thanks Xerxes! OK, next question then - can I get rid of the stain from the knotting solution that I inadvertently used on some knots already?! I guess I could try sanding it out?
If you don't use knotting, the solvents in the resin in the knots will dissolve the varnish, or stop it setting for months or even years.
hmmm, so one vote for "you don't need to do it" and one vote for "you must do it" - anybody care to tip the vote one way or t'other?!
Go ahead and varnish it without the knotting.
If it really doesnt dry (which i highly doubt) you will be in a position to simply wipe off the varnish and use knotting the next time.
I have never experienced varnish failing to dry for want of knotting but then i have only used yacht varnish and various types of polyurethane.
OK so someone says it doesn't make any difference. Let me tell you that I had a large, expensive piece of varnished wood which had part of a knot in that exuded resin (on a boat, using yacht varnish). It dissolved the varnish and ran down the wood. Fine, it could be rectified afterwards, but if it had been done in the first place it would have been done only once.
So it's your choice.
