Varnishing skirting boards
5 Mar 2005
I fixed all the skirting in my house with screws/wallplugs and I covered the screw holes with natural woodfiller.
When I varnished the skirting then the holes that I put the wood filler in are REALLY visable.
What can I do?
helllooo s999 and welome
unfotunatly it gets worse as the pine gradualy ages the filler becomes more apparent
the only real ways to drill out the filler and plug with with plugs off wood
if youved used these http://www.toolstation.com/messages.html?code=40882&mainWin=1
if the screws are close to the surface[less than 6mm] drilling out wont work as you wont clear out enough for a plug to fit in
you cut plugs with these http://www.toolstation.com/search.html?searchstr=64444&Search=1
cut from simmilar grained wood
or live with it
Big-all pretty well says it all. Those wood fillers might look the same as the surrounding wood when they're dry but once you put the varnish on the stuff acts like end-grain and your filled holes look like knots. It wouldn't be so bad if they didn't look like perfectly round, regularly spaced knots!
Actually, I never buy wood filler for this kind of job. I save the sawdust and mix it to a thick paste with varnish. It works a treat on small cracks. It sticks to the sides and remains flexible - but it's still visible.
another solution if you just cant live with the circles is to carefully remove the filler then the screw[laborious and time consuming]and as dewy would say replace with slightly longer brass screws and cups
http://www.toolstation.com/search.html?searchstr=69705
but this will only look any good if your screws are reasonably placed and in line
good luck
I cheated once by cutting the screw as short as possible with superglue into the cups and then the wood. Good idea if you don't want to upset the varnish.
naaa thats not cheating its called ingenuity and i like it :D :D :D :wink:
oo and another choices for removing filler is to take a screw /screw it in if your lucky the filler will pop out if not [some will]tap a star screwdriver rotating slowly till it locates in the screw give it a sharp tap blow out dust now if your lucky the the filler will either fall out as you do this or be pushed out like a plug as you extract the screw
