    Dismiss Notice
Varying mains water pressure upstairs
Discussion in 'Plumbing and Central Heating' started by PlumbBob, 1 Apr 2020.
  1. PlumbBob
    PlumbBob
    30 Dec 2003
    32
    Thanks Received:
    Country:
    Hi
    I have an electric shower in the en-suite that takes it cold feed from a T off from the same pipe that feeds the 2 header tanks in the attic - so it must be the mains. From that is a smaller bore copper pipe of about 2.5m length to the shower. However the flow changes from 2 to 4 l/min.
    What causes varying flow rate? Just low pressure? (But would think it would be constant)
    Shower is struggling to deal with the varying pressure and will stop heating the water.
  2. Sponsored Links
  3. terryplumb
    terryplumb
    8 May 2017
    6,143
    Thanks Received:
    1,271
    Country:
    More likely to be a fault internal to the shower ,stabiliser valve possibly. What make / model is the shower ?
    Are you sure it's under mains pressure ?
    2 to 4 litres per minute is very low ,what is it when on fully cold ?
  4. PlumbBob
    PlumbBob
    30 Dec 2003
    32
    Thanks Received:
    Country:
    Ive took the shower unit out the equation and measured the flow going into to the shower unit
    I need to measure the pressure and compare with downstairs yes.
  5. terryplumb
    terryplumb
    8 May 2017
    6,143
    Thanks Received:
    1,271
    Country:
    Do you mean you have totally removed the shower ,and the open pipe flow rate is ,2 to ,4 litres per minute ? If so what is the pressure ,static ,at the open pipe ? And what's the dynamic pressure ?
  6. PlumbBob
    PlumbBob
    30 Dec 2003
    32
    Thanks Received:
    Country:
    I removed the shower yes.
    To confirm whether variable flow was due to the shower, but it isn’t.
    I’ve not checked pressure - I’ll do that, may need some form of adapter.
    I’m thinking if pressure is low then flow is going to be weak.
  7. Sponsored Links
  8. terryplumb
    terryplumb
    8 May 2017
    6,143
    Thanks Received:
    1,271
    Country:
    It would ,but if the flow is not constant ,then pressure has to fluctuate or there is a mechanical ,inconsistent ,intervention in the pipework. Always assuming it is mains fed and not gravity fed and ruling out airlock.
  9. Madrab
    Madrab
    4 Oct 2012
    8,210
    Thanks Received:
    2,337
    East Renfrewshire
    Country:
    Are you sure it feeds the 2 cisterns in the attic? I would follow and confirm that the pipe that feeds the shower connects to the ball valves in the cisterns and isn't supplied from the body of one of the cisterns. It sounds more like the latter given the flow you are seeing.
    • Like Like x 1
  10. PlumbBob
    PlumbBob
    30 Dec 2003
    32
    Thanks Received:
    Country:
    Hi, yes it has been Tee’d off the cistern’s feed pipe, probably when the house was extended. I’m not too happy about the smaller diameter so for price of it may change that out for 28mm until final 10cm
  11. terryplumb
    terryplumb
    8 May 2017
    6,143
    Thanks Received:
    1,271
    Country:
    Pointless . All you need is 15mm ,what do you have ?
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
