Vauxhall combo 2010 1.3cdti - both headlights not working.
27 Jan 2010
Buckinghamshire, Darn Sarf
It's not the lamps!
It's probably not the fuses, as it seems there's one for each lamp.
Both main beams work properly.
Both parking lights, and both tail lights, work.
I suspect a relay, but as there is no indication of which relay or fuse does what on the fusebox lid then I will have to check every fuse and relay sequentially unless some kind soul can point me towards the location of an online wiring diagram.
MM
Thanks for your inputs.
@baldykev there is a fuse for each dipped headlight, so the chances of both failing is remote.
On further inspection during daylight hours I found that one lamp had indeed blown, the other having a poor electrical connection. Both now cured, both headlights working again.:idea:
It's not the lamps!
that was not a correct statement.
