Hello all, I have a 2011 meriva with ac (just recently purchassed) first day of going to use the air con and although light comes on no ac. Took it and had it regassed fully, no sign of leaks and noe full to correct levels, still not working. When turning on ac the revs appear to try a climb for a second then nothing and no ac.
Does anyone know if the cooling fan should start when ac is pressed as it does not. Also anyone know what temperature it should cut in at when coolent reaches certain temp ?. It is not showing as overheating although it reaches running temperature very quick. The gauge seems to sit perfect but engine seems to be really hot.
Two queries any advise greatly recieved. When i got it I thought th ac was working but it wasnt a hot day so it may actually not have worked at all.
