my Vaillant VCW242E has not been firing up it's CH. HW works fine, but CH never triggers the ignition. All the other sounds seem normal like the pump, just doesn't do the 'click' and ignition.
I've had a guy come round and he checked the divertor valve but he doesn't think that's at fault. He had a good look around, including the switches at the front of the boiler but no joy. He managed to get the CH to fire up but only by switching the main switch on the boiler off then on, which seems to do the trick. But if it stops for any reason it won't start again without the off/on trick, so if the HW triggers and stops, CH won't make it back.
He plans to speak to Vaillant technical as he isn't sure where else the problem could lie. Anyone have any clues?
