Vectra Gearbox crunch
22 Jan 2011
Kent
Hi,my Vectra 2.2i sri 2002 has developed a crunch when i change down from 4th to 3rd :( !Can anyone tell me why this is happening!
usual cause is clutch, not dis-engaging fully, have you got thick footwell mats, possibly restricting full clutch pedal movement?
Wotan
It sound like your 3rd gear synchro cone is on its way out.
Yes, if all the other gear changes are OK then its third gear. Secondhand box from a breaker if your on a budget. You will probably have to change the clutch disk when you have the box out so factor that into the bill.
Double check the oil level in the gearbox if you want to cancel all the easy stuff out. But most likely the level will be fine.
You can change your driving style and see if that helps. The box could last forever if its not abused. Try jumping third, or a slower change might help. You could always try the link below.
http://www.madabout-kitcars.com/kitcar/kb.php?aid=190
Imagine two gear shafts that need to be coupled together.....if they are rotating at the same speed this should be quite easy, right? This is done by the synchromesh cones in the gearbox. Once the shafts are at the same speed, they are locked together by the synchromesh hub. So, if you have zee crunch, its the synchro cones that are tired. Chances are the gearbox will go on for ages, and it will start jumping out of gear before the crunch gets worse.
John :)
Thanks for your reply,did wonder whether it might be the synchromesh on the way out,kinda hoping it was something else!Another gearbox needs to be sourced!
