Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
My 5x2 are slightly too short to go from ridge beam to eaves when framing out my velux - is it possible to join two pieces (which themselves will be bolted to existing rafters) or does that contravene building regs?
Thanks Catlad - i'd say its about the same length as the original rafter (i.e. 5x2 at 4.8m length which seems standard) but the original sits on a joist. Perhaps it might be an idea to sit the new framing on a block in the eves imitating a joist? (assuming it would pass building regs and/or building regs don't care?).
