My closed central heating system has been fine for years. 6yr old Baxi combi boiler, 11 radiators. One bedroom radiator was discovered to be full of air (more air than water I reckon), so I vented it. In doing so the system pressure dropped, as you'd expect, and the air stopped coming out, so I closed the valve and topped up the boiler pressure back to 1.5 bar, then continued to vent the radiator. The pressure dropped again, so I went to top up the pressure on the boiler only to find when I returned to the radiator that I'd failed to close the vent completely and there was water on the floor. With the air now entirely vented I closed the vent fully and checked the pressure on the boiler and topped it up again to the green, around 1 - 1.5 bar.
Later on that same day I checked the boiler pressure and it was right up in the red, well beyond the green safe zone and close to the upper limit of the dial, nearing 4 bar. I panicked and quickly vented some water from the nearest radiator (kitchen) to reduce the pressure in the system back down to green.
That was all several days ago. Since then I've monitored the pressure and found that first thing in the morning the pressure is at zero and the boiler in error. I have to top it up (takes about 4 seconds) and it comes on fine. During the day the pressure sits between Green 1.5 and Red 3 bar (depending on temperature of water I guess) and runs all day. Heating goes off overnight, then next day it's back at 0 bar and needs topping up again. Note the boiler has an over-pressure release valve set to 3 bar (according to manual).
I've got two questions:
1. Since venting the air I now cannot maintain the pressure in the green zone, it always reaches red. Do I need to get air back into the system somehow? It feels that with no air in the pipework it cannot accommodate the expansion of the water when heated and the system goes over-pressure. Shouldn't there be an expansion vessel in the boiler for this purpose? Can I test if it's failed somehow?
2. I have to keep topping it up, which suggests it's losing water. I checked every accessible pipe joint, rad valve etc., and found no water anywhere. Could the boiler be releasing water into the overflow pipe that goes outside? This might explain why I can't track any actual water loss in the house. What does the safety discharge valve look like and where is it? I don't mind sticking my nose in the machine to find it and check for water.
Details: Baxi DuoTec combi, 28kW, Condensing Combination Boiler. Fitted about 6 years ago. Detached 4 bed house.
