M
MopeyGecko
I had a plumber around today to carry out an initial survey to see what would be required to upgrade my heating requirements and just wanted to check a few things over with you guys if you don't mind.
Firstly I have linked to a diagram of the current system as it stands now.
The objective is to have a central heating system installed. In my mind before the plumber came out I was expecting to be able to replace the solid fuel boiler with a gas one and add the central heating radiators to this keeping the rest of the system as is and away we go! Now for the outcome of our discussion....
Firstly apparantly I cannot use the existing chimney that the solid fuel boiler is using and would have to run a new flue out of the side wall (house is a listed building so I am reluctant to do this even if it is allowed)
Secondly he was leaning towards an unvented system getting rid of the cistern in the loft but adding a storage cylinder in the kitchen below the boiler with a pressure vessel? thought I understood at the time but I'm confused as to why this is necessary now and whether it is just creating unneccessary work.
Third he mentioned that because the pipe run from this new storage cylinder to the bathroom was quite long he would recommend adding a return pipe to keep the circulation right up until the point of use. (this I understand but surely if the existing storage cylinder/immersion heater is in the bathroom in any case and the boiler is sat right next to the kitchen sink this is a non issue correct? (only an issue if he's introducing this storage cylinder below the boiler in the kitchen)
Lastly there is a 2nd WC and washroom some distance from the tank in the bathroom which currently goes up into the loft, along to the corner of the building and then down to the ground floor. He mentioned removing this pipe and taking it a shorter route along the first floor and then down and back again. I think this makes sense with the current system but with his new proposed system surely it would be better running along the ground floor direct to the room in question?[/list][/list]
