Hi all,
Got a bit of a tricky situation, and would appreciate input from forum members.
(Ventilation seems to be an area, which is often overlooked, given its importance)
Pics included.
Room: Wash basin, toilet, shower cubicle (No bathtub).
Room - Dimensions = 1.81m long by 1.74m wide by 2.53m tall
Exhaust ducting = 100mm diameter by 300mm long.
I used this to do the calculation - but I have no idea if it is out of date - or is wrong. It suggests that I absolutely need a 120mm fan. Don't know how seriously to take it.
So -
1. Clearly it would be very easy just to put in another 100mm/ 4inch fan, but there must be a
reason that a larger one is suggested? Would it really make a significant difference?
2. If a more powerful/bigger extractor is needed, what might be the simplest solution here? Is there a way to couple a larger fan say 120mm/ 5" fan, to this 100cm existing tube, and have it work out okay? (I'm hoping to avoid replacing the exhaust tube with a larger diameter one).
3.What brand of fan/extractor would you recommend?
4.Any thoughts or alternatives you might care to suggest or that come to mind?
My thanks to all that contribute
SirLancelot
Pics included.
So -
SirLancelot
