Veritas R8 Improvement
4 Nov 2013
I have a Veritas R8 alarm system that was installed as part of our new build house.
It’s a Veritas R8 system with 4 PIRs and 1 remote keypad located at the front door.
Are there any options to upgrade this system?
Whether they be texecom products or otherwise, but ideally I’d rather not need to start installing new wires.
Yes there are options but they are limited so as asked what is it you want upgrade the panel to do?
The R8 has no outputs as such, but the bell trigger and sw+ could be used as outputs to trigger a dialler for alarm and set and unset conditions potentially.
As pstn is being phased out, IP based and gsm modules might be worth looking at.
A cheap easy to program gsm unit has been discussed on here before.
If you want to voice call via gsm it tends to be more expensive.
Apps can be used but primitive and limited on the Veritas Compact, Veritas 8 and The Veritas R8, the R8+ and excel panels for example have pre defined outputs making more possibilities open up.
I would be tempted to look at upgrading the whole system if you want an app to be fair.
Sorry, what a rubbish post!!
I guess I’m looking for anything extra... from remote keyfobs to a full app system.
I can’t make use of the Veritas system installed I guess the wiring I need is there to get me started for the main board..
The easiest upgrade may be a Premier Elite panel, depends on what you current have and want as to a full kit recommendation.
Hello,
I need some useful advice for DIY upgrading our old VERITAS R8 alarm system.
This alarm has been in use for over 20 years and we want to replace the old control panel & keypad by the new VERITAS R8 plus or Excel, and keeping the existing wiring, sensors, and bell box etc.
I intend to do it as DIY and need your advice or useful experience if you did similar project in the past.
thanks
It’s not a route I would take with those panels ….premier 24 or euro46 would give more flexibility going forward …
